Yeah but what determines as close as possible?  "Possible" implies lack of surety that it matters.
So if the panel is already populated but at the bottom, do we have to move all breakers?  Or does the "as possible" part mean it doesn't matter if inconvenient?  Is there a practical difference because there is a minor esr difference in a large fault current, or is the fact that the fault current is high mean it doesn't much matter?  Does L di/dt apply to the inductance of the bus bar, and the length to the SPD changes inductance much?  Does the entire electrical,distribution downstream turn into one big inductor if it's not bled off in the first position?
This isn't a "read the manual" question.   That's exactly why I put it in the electrical calculations and engineering section, so the theory could be discussed instead...
