A client has recently run into some trouble with their safety inspector and I'm trying to figure out a solution that will allow them to continue working.
They had been installing branch circuit wiring onto the load side of breakers in a switchboard. The breakers they were making connections to were properly turned off and locked out, but the neighboring ones were not. The line sides of the breakers are continuously covered, but the load sides remain exposed. Since this work is in a datacenter-type environment, turning off all the breakers is unacceptable. The inspector has forbidden them from doing this type of work unless the power to all the breakers has been disconnected.
I am trying to devise a solution where each breaker's load side is connected to a dead-front terminal block. The load terminal of the breakers can remain enclosed, and all wiring connections will be made at the terminal block. Since the terminal block is dead-front, there are no "exposed" live conductors. The terminals that will be worked on will be disconnected as per normal.
I've tried to research the OSHA rules on working in live panels, but I can't seem to find anything saying that working near "unexposed" live conductors in a box is okay. Does anyone here know if this might be acceptable? Does a dead-front terminal block actually satisfy the requirements for covering a live conductor?
Thanks.
Thanks.
