Electric-Light
Cognitive bias testing
iwire, here's an awesome cognitive bias testing
Several conference rooms used to host classes for lighting and electrical personnel.
Classrooms are fitted with volumetric recessed luminaires that hide the lamps and cleverly fitted with both 48" T8 RE80 4100K and 48* T8 4000K dimmable Cree T8 drop-in lamps and on separate switches. A remotely controlled contactors are used to select between F32T8 vs LED. They're both on dimming ballasts.
AM, classroom 1: Mode selector is set to Cree LED lamps at the AV room, dimming controller set to bypass. Room lighting is shut off for presentation slides and accomplished by the instructor asking the person near the light switch to hit the switch. 2x4 ceiling panels are kinda dirty, some with stains, One near the podium has a broken off corner.
PM, classroom 2: Mode selector is set to utilize F32T8 841: Same students. Instructor activates the projector. Lutron Grafik Eye coordinated with AV system fades the lighting down to 1% smoothly and ramps up to 100% smoothly. The room has immaculate 2x4 panels. Sometime during the class, instructor mentions he was told the room was recently upgraded to the latest LED technology.
In the second example, CEU students are purposely told the classroom using the F32T8 841 fluorescent lamps was retrofitted with LEDs. These same students attended the first part of class day before in a classroom that was actually LED lit in earlier part of the day.
Now let's see what happens when they're surveyed at the end and the comments they write.
Do you believe that comment on LED upgrade and the added touch of dimming affects the survey results?
Session 3 the next day can discuss the survey results dispelling the LED myths.
