davedottcom
Re: Outdoor condensing Unit
Ok, I found the service manual!
Bob's right. The sump heater warms the bottom of the compressor to keep the refrigerant there in a gaseous instead of liquid state. (If you had a cold night, the refrigerant might condense into a liquid. If you tried to start the compressor with liquid in it, that would be bad.) I'm surprised that you'd even need a sump heater in FL. Does it often get down to 45 or 50 degrees where you are?Originally posted by davedottcom:
You'd have to remove the refrigerant and braze in a new one.Originally posted by davedottcom:
Jim K,
Yes it gets below 45 here! It goes way below that at night during the winter months. I've had ice/frost on my car windows many times. Of course it goes right back to 60+ when the sun comes up!
And yes, the compressor is running, I swear!
I remember this happening a few months ago now that I think of it. All of a sudden the AC vents were putting out heat! I messed with the t-stat and next thing I know the ac was back on.
I had replaced the t-stat thinking that was the problem but there was probably nothing wrong with it after all.
Is this reversing valve something easy to change?
Or does it involve draining and recharging the unit?
Dave
