hhsting
- Glen bunie, md, us
- Junior plan reviewer
Does outdoor parking metal light poles require ground rods be installed at each light pole NEC 2014?
Where in NEC 2014 it says equipment grounding conductor is required for light poles?
A ground rod will NOT trip a circuit breaker you need an EGC back to the source to trip/clear a breaker. A ground rod would only be required in ADDITION to an EGC on detached structures. A light pole is not considered a structure.Where in NEC 2014 it says equipment grounding conductor is required for light poles?
I think it is considered a structure but one that is exempt from the requirement to have a ground rod.A ground rod will NOT trip a circuit breaker you need an EGC back to the source to trip/clear a breaker. A ground rod would only be required in ADDITION to an EGC on detached structures. A light pole is not considered a structure.
