jph320
- Cinnaminson nj
- Electrician
If an outlet above a sink is 6 ft high does it need to be going in a hospital
An outlet was installed 6 ft off ground and it is above the sink. Should it be gfci. How hard is that
517.21 Ground-Fault Circuit-Interrupter Protection for Personnel.
Ground-fault circuit-interrupter protection for personnel shall not be required for receptacles installed in those critical care areas where the toilet and basin are installed within the patient room.
How hard is that
I not sure what you are asking. Is this a play on words?
As if your high (drugged) you need to go to a hospital,
Or are you actually trying to ask a question?
:lol:I'm thinking the OP got annoyed, so I'll do my best to answer his posts with no additional information.
No, an outlet above a sink 6 ft high does not need to be going in a hospital, it can be going just about anywhere.
If this is a 120 volt receptacle outlet then it must be GFCI protected with an in-use cover regardless of the sink since it is installed 6 ft above ground which in turn locates it outdoors. If this is a lighting outlet, no GFCI protection required.
Quite hard, thank you for asking.
Personnel. Ground-fault circuit-interrupter protection for
Sorry I did not state GFCI in first post. and yes it is in a patient area. I did not install this I just seen it doing a walk through and had a concern.
