Outlet Facing
roger
Fl
Retired Electrician
Re: Outlet Facing
Bennie is absolutly right. ;)
Roger
roger
Fl
Retired Electrician
Re: Outlet Facing
Sorry Bennie, Mike is absolutly right. :D
Roger
roger
Fl
Retired Electrician
Re: Outlet Facing
Sorry Bennie and Mike, Peter D is absolutly right. ;)
Roger
r R
e o
g g
o e
R r
regoR
mikeackley
Washington
Re: Outlet Facing
Do you realize we have just proved Einstein?s general theory of relativity? If there is no right answer, and if there is no wrong answer, then Black Holes must exist! :eek:
bennie
Esteemed Member
Re: Outlet Facing
gm: We are pulling your leg a bit. This is your initiation rutual :p
Best regards: Bennie
al hildenbrand
Minnesota
Electrical Contractor, Electrical Consultant, Electrical Engineer
Re: Outlet Facing
I think quantum physics and the Heisenberg Uncertainty Principle dominate here.
The harder one looks the more uncertain the position.
:D
roger deas
North_Carolina
Re: Outlet Facing
gm, I second Bennie's post.
Welcome to the forum.
I think Mike and Al may be right. ;)
gm here is an answer to your question. (I promised iwire I wouldn't do this again, Sorry Bob)
Roger
[ April 04, 2003, 10:28 AM: Message edited by: roger deas ]
ronaldrc
Tennessee
Re: Outlet Facing
You'd never know I'm getting bored would you thats almost as bad as changing the air in you're tires ain't it?
To take the time to make a post like that I mean.
But someone has to look out for us leftys'
Ronald :roll:
bennie
Esteemed Member
Re: Outlet Facing
It is common sense that the ground connection faces towards the ground. Otherwise it would be called a sky connection ;)
mikeackley
Washington
Re: Outlet Facing
Ronald: I think you lefty?s might be onto something here. If that four-plex has breakaway tabs, you could wire up a special assembly, labeling each receptacle: Dedicated circuit; General lighting circuit; AFCI protected; Non-AFCI protected. Such a device along with a plug-equipped smoke detector might go along way to satisfying that controversy. :cool:
