T tonype Senior Member Location New Jersey Nov 11, 2012 #1 Bottom of panel is about 11" to ground - too low? Inside cover is also corroding (though the rest is in decent shape with no interior corrosion).
jumper Senior Member Location 3 Hr 2 Min from Winged Horses Nov 11, 2012 #2 Neither the NEC or IRC defines a minimum OCPD height for this application. Local amendments may apply.
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician (retired) Nov 11, 2012 #3 Not a code violation.
iwire Moderator Staff member Location Massachusetts Nov 11, 2012 #5 tonype said: But a pain for you guys to work on!! Click to expand... Yeah for sure, but those lift up doors usually pull off with two screws so if I actually had to work in that box that is what I would do.
kwired Electron manager Location NE Nebraska Occupation EC Nov 11, 2012 #6 Not a violation but some will say it is poor design. I often find any enclosures like that mounted near grade will usually have a greater risk of corrosion
iwire Moderator Staff member Location Massachusetts Nov 11, 2012 #7 kwired said: I often find any enclosures like that mounted near grade will usually have a greater risk of corrosion Click to expand... I have to write this revelation down.
kwired Electron manager Location NE Nebraska Occupation EC Nov 11, 2012 #8 iwire said: I have to write this revelation down. Click to expand... Yes, after nearly 25 years in the trade this first occurred to me now
R Ragin Cajun Senior Member Location Upstate S.C. Nov 12, 2012 #9 Definitely a back ache. The grounding electrode is not protected nor is the "ground" for the cable or telelphone. Interesting how the radon fan is external. RC
electricguy61 Senior Member Location Remotely running business in Bay Area, CA from Med Nov 12, 2012 #10 My question is: Why install it like that? Save the cost of an LB?
