roy25101
New member
- Orlando, FL
During a residential inspection of an out building, every outlet tested shows a faulty ground but only when there is a load on the circuit. If all loads are removed the ground shows to be fine. Any input on this one would be greatly appreciated. An interesting note, when a load is placed on the circuit, the tested resistance between the neutral and ground increases.....
Thank you..
Thank you..
