In a somewhat related story...
For years I drove a 1971 Ford Econoline van. It did this annoying thing; I would just be driving along when suddenly the engine would shut down and would not restart. When this happened I would pull off the engine cowling and kind of poke around, find nothing amiss, try to start it, and it would light right off and run fine... for a month or two, when it would happen again. This went on for a couple of years before I finally found the problem. On the top front of the engine there was a heater hose that attached to the engine with a hose clamp, and the side of the clamp was in contact with engine metal. The 12V supply line from the distributor points to the coil was in contact with the tag end of the hose clamp and over time it had worn a tiny notch through the insulation on the underside of the wire where I couldn't see it. Short to ground, dead engine.
Whenever I would poke around under the engine cowling the wire would get moved so that it was no longer shorted to ground, so the engine would start up and run fine for a long while, but eventually the notch in the insulation would find its way back to the clamp and shut things down again. It drove me nuts.
