outlets above floor vents
gregorsc
I just wanted some advice , I have a church room that has underground floor vents and they want an outlet 16" above the floor directly over the vents is this leagal?
Re: outlets above floor vents
I don't see any problem with this. I assume you mean vents for regular forced air heat and air conditioning. The air wouldn't be hot enough to cause any problems.
An outlet above a baseboard heater would be different.
Steve
Steve,
Your comment "...outlet above a baseboard heater would be different" should be modified to read: "outlet above an electric baseboard heater would be different".
There is no problem with installing outlets above hot water (hydronic) baseboard heaters.
