abdo1984
- Cedar Rapids, IA, the USA
For outside installation consisting of two wire branch circuits, what amperage rating should the building disconnecting means have?
You're welcome but I'm not sure your answer is correct based on the way you worded the question.Thank you Roger
The disconnecting means shall have a rating not less than 30A.
And that is the correct article, 225.39 to be exact.a came about the answer from the NEC Article 225. out side branch Circuit and feeder.
