hhsting
- Glen bunie, md, us
- Junior plan reviewer
Where in NEC 2014 it says if buildings on same property and under single management can be served by feeder?
The details on Feeders in regard to single management are in Art 225 as kwired notes. Very easy to find..big bold letters.
I have single feeder from one building to another and buildings have single owner for both and on same property.
I did not find wording single management 225.30 single feeder is ok. Where is it? Can you please elaborate?
Having single management is irrelevant to running a feeder between buildings.
You may be thinking of 225.32 Ex No. 1 for disconnecting means location.
That's because it doesn't exist.No documented switching procedure exists.
Some people argue that building or structure can only be served by service 230.2.
However building I have is served by feeder from another separate building same owner both buildings single management same property
I thought I read somewhere in NEC 2014 if its under single management building can be serve by feeder. If not and two different owners than building must be served by service only. I just cant find it.??
If second occupant is leasing you possibly run into that. If separate owners they generally want their own service. If you sell off the second building that was feeder supplied, generally the feeder will get disconnected and service will get run to the second building. NEC doesn't really address this though other than accessibility to your overcurrent devices.So lets say if bldg 1 os owned by owner 1 and bldg 2 owned by different owner 2. Code would allow outside feeder from bldg #1 to bldg #2? What about accessing their own overcurrent protection and all that?
What did AHJ say about local requirements?What about accessing their own overcurrent protection and all that?
The language is in 225.30 (E) and allows for more than one feeder supply to a building under those conditionsWhere in NEC 2014 it says if buildings on same property and under single management can be served by feeder?
