Outside outlet 18” high
What rule is that? I've never heard of it and I don't think that it's in the NEC.
Sometimes it will be designated on your plans. If not I would put it to the bottom.I think both are actually higher than ADA standards.
I'm like Infinity, what rule are you talking about?
Roger
Commercial or residential? 18” is a height specified on a lot of commercial jobs.But if you refer to Informative Annex J (ADA) lowest measurement is 15”; and it is to the bottom.
Got in an argument with my tech school instructor in the early 80's, he said it had to be 18". I asked him where in the code does it say it. He couldn't. I think it was a Union thing, as he was IBEW previously.
I was IBEW. Not a bad way to go for me.:rolleyes:
If this is for a single family dwelling put it wherever you want. I've seen these almost at ground level.
If your outlets aren't mounted exactly 18" to the center above finished floor or grade, you can get 3 months in prison for this violation.
Better measure twice.
NEC code: 320.25.81, section BS :)
