I have a pump, that has a 3ph 460v 15HP motor. The pump has an oil system on it. We have decided to add an oil cooler to the pump, and It comes with a 3ph 460v 3/4hp motor on it. They will both run at the same time.
I am trying to find where the code will allow me to combine the loads and use the original 15hp overloads, with adjusted settings. The code says I can use the same disconnect, circuit, starter. But I can not find if I can combine the loads on the same overloads.
