i have 600watts of load on a 600 w dimmer what will happen if the customer changes bulbs to higher wattage.and it exceeds the 600 watts Will the dimmer have an overload in it or will keep getting to hot and cause a fire?
.... Likewise the 100 watt dimmers would be rated 800 watts. ............
Can someone show me anything that tells me dimmers are not designed for 100% loading?
For both residential and commercial use. Stylized knob provides dimming, on/off control and indication of light level setting. 6" prestripped wire leads for fast, easy wiring. Ground lead provided. Wraparound heat sink dissipates heat and does not require de-rating. Longer strap increases wallboard contact area.120 Volt AC, 60 Hz. UL Listed. This Cooper Rotary
Usually, it's my customers.
I intentionally derate dimmers solely to prevent them calling me about "hot dimmers that are going to burn my house down!!!!" I prefer to avoid the situation altogether and over-engineer.
somebody, somewhere was once (correctly) told that when installing side by side dimmers in the same box they must be derated...this led to mistaken belief that no dimmer can be loaded at 100%...URBAN LEGEND STRIKES AGAIN!!!
