noel westphal
Have a question about the proper circuit breaker size for a septic lift pump, the pump is a 1 1/2 horse power and has a max amp rating of 15.7 amps the control panel has a factory installed 30 amp Square D breaker inside it as a disconnect. If you used 10-2 UF to feed this could you put it on a 30 amp breaker or would it have to be a 20 or 25 amp. Thanks, Noel
