Here are (some of) California's rules on overhead high voltage lines. There is an old structure directly under some transmission and distribution lines with more than 12ft vertical clearance. Trying to figure out if the same thing could be built today.
(c) Clearance from Buildings. Open high-voltage conductors shall be substantially supported independently of buildings or structures and shall have a clearance from buildings or structures as follows:
(1) They shall be maintained not less than 6 feet horizontally from buildings or other structures or any portion thereof. Where the vertical distance above ground of conductors of 7,500 volts or less is in excess of 35 feet, this horizontal clearance from buildings shall be permitted to be less than 6 feet, but shall be not less than 4 feet.
(2) They shall be kept not less than 12 feet vertically above any part of buildings or structures over which they pass.
I find this a bit confusing. If you have to have 6 feet horizontal clearance, then how can lines pass over a building with 12 feet of clearance? If the line is 6 horizontal feet from the building, then it would not pass over the building.
Or is the horizontal clearance specifically for buildings next to lines where the vertical clearance doesnt exist? For example a tall building next to some power lines?
