newservice
I know this has been asked in different ways before. Garage is 60 feet from the house, with big eaves, so it needs a mast to achieve clearance from the roof and ground and driveway. Presently 14-3 romex loops around a ceramic clevis screwed half way up the roof into the roof shingles, and goes through a hole in the shingles into the garage
Customer only wants 2-20A circuits. which could be done with 10-3 UF. Customer says dont want underground...
Questions are: Since this would need a mast of some sort, can I do a 10-3 UF cable with a messenger wire , and if so, can I bring that into pipe somehow to maintain the roof clearance? Do they make raintight heads for 10-3 UF? Otherwise I guess its the quadplex cable type entrance that Ill be doing.
Thanks in advance.
Thanks in advance.
