svaurez
- California
When you drill up through the roof to install a service mast,how do you line up the hole so everything is level?
Do you install the panel first and then sight the hole off of that,or do you drill the hole first and then mount the panel?
And finally,what is the best way to drill through stucco?Any special hole saws out there that you can recommend?
Thanks
Thanks
