If I run a hot conductor to a motion sensor, it seems I would violate code by running another hot from a switch, since the motion sensor would be trying to feed it each time someone walks by, from the same breaker leg, but off of another hot.
I was thinking of a double pole switch that turns off the motion sensor feed, when it is turned on, or a relay, but not sure if anyone has already worked this out.
