Oxygen Metering room
Zifkwong
Is a room which has a significant amount of pure oxygen, contained within pipes, a hazardous location as per the NEC?
Although oxygen in itself is not flammable, any fire in that room would be greatly accelerated if there was an oxygen leak at the same time.
If it is not considered a hazardous location, does the NEC have any specific section or sections which specifically cover these types of rooms?
In order to to give you an idea of the magnitude of oxygen present in the pipes in this room, they are being fed from a 20 MW oxygen plant.
This may help
This may help
OSHA 1910.104 Oxygen may help you on Oxygen storage, piping, ventilation, distance form other materials and opertions etc..
