I just use this. It only takes a couple seconds if you cut in the direction of the slot.
But if you can't find the slot, it does get trickier.I just use this. It only takes a couple seconds if you cut in the direction of the slot.
Screw driver as described. Is that eight?
When the paint is that thick it will usually chip off (atleast enough to find the slot) when rapped a few times with the side of linesmans.
Not this stuff. It is almost like semi-hardened glue. You have to dig it out, or grind it out.
I still say your best bet in your situation is the screw extractor. It never hurts to have one on hand and HD has them for about $20 for the set.
Screw extractor? Maybe- but why bother? If you must, visit harbor Freight. While you're at it, get some left-handed drill bits. They'll come in handy some day.
Cut / break the plates off, even cut the screw heads off- and grab what's left with Vise-grips and turn.[/QUOTE]
I was kind of starting to think the same thing. At some point just trying to get the screw out is going to be costly.
yeah let's take 5 - 10 minutes per device instead of 1 minute with the screw extractor. I used these things on some corroded screws in some concrete encased step lights and they came out easy and fast. Before that we tried needle nose, side cutters, etc....wouldn't even turn the screw. If time is of no essence and a $20 solution doesn't work for you I totally understand.Screw extractor? Maybe- but why bother? If you must, visit harbor Freight. While you're at it, get some left-handed drill bits. They'll come in handy some day.
Thanks.
I was just going to ask if I could get them somewhere besides on line.
