AHJ - 373-8 312-8 & other "Really?" Moments
I have "discussed" at length these sections of code. I thank all you gentlemen for you comments and input.
I have had inspectors who (not relating to this issue) Fail service inspection, because they could not "see" the connection to the ground rod even though a pole mounted service with grounding conductor nailed to pole leading to rod six inches from base installed below grade per code. Demand a back-fed 30/2 main for a 120/240 code minimum pole service installed with six circuit 3R panel with 1 20/1 feeding into 3R j-box below with single 20A receptacle in handy box to provide power to an irrigation timer, because inspector "felt" additional load might be added. We are talking in the boondocks locations with obviously no other loads to be connected in future...I disagreed, pointed out the exact code references allowing installations and LOST to NEC AHJ has final authority. I did win one using illustrated NEC Handbook, when the inspector failed service replacement stating the "meter & panel" too close to the window. I pointed out my NEC reference and my understanding (with the lovely picture diagram) that service entrance "CONDUCTORS" could not be within 3' of a door or window to prevent people accidental contact...
Greatest amount of egg on my face early in my career (Oh my gosh, 38 years where did they go) - : Building a residential 400A single phase 120/240 service for one of our commercial customer presidents who adding a covered pool with motorized dampers...I ordered long barrel compression lugs for the 500KCMIL cu service entrance conductors...electrician called me to say local utility would not tap meter because of lugs, we were to cut and use short barrel mechanical lugs provided with the meter...I LEFT FOR JOB AND went off on the utility foreman with "Are you trying to tell me these short mechanical lugs, (waving one in his face) are better wiring connections than these long barrel crimp connections in the meter can?" He smiled appreciating my young animation and said, "No sir, I'm not telling you that the lug in your hand is an "APPROVED" connection"...they weren't Burndy, Blackwell or other approved they were SQD...exit left with apology...
Have a great new year everyone...Here's a toast for profitable projects, installed with pride in a neat and workmanlike manner!!!
Last but not least:
Sad statistic from trade magazine EC or ECM 4 years ago...Average age journeyman electrician (at that time) was 56 years old...
Steve
