I submitted a PI to add one item to the list in 250.118 "(15) Metallic equipment enclosures." My substantiation is below. Feel free to submit your own PI or to propose a better substantiation, I'm happy to change my PI.
Cheers, Wayne
There is currently a conflict between 250.118, the definition of Equipment Grounding Conductor, and common practice.
When using an equipment grounding conductor not of the wire type, such as rigid metal conduit, common practice is to rely on metallic equipment enclosures, such as a panelboard cabinet, to provide continuity for the "ground-fault current path" between sections of conduit. As such, per the Article 100 definition, metallic equipment enclosures are Equipment Grounding Conductors. And they certainly "enclose circuit conductors", so they fall under the scope of 250.118. However, the list in 250.118 does not presently include metallic equipment enclosures.
The simplest way to resolve this logical conflict would be to add an additional item to the list, "(15) Metallic equipment enclosures." If the Technical Committee prefers, the scope of 250.118 could instead be limited to equipment grounding conductors run with or enclosing circuit conductors "between equipment enclosures."
