difowler44
I have never seen a minimum height requirement for a residential indoor panel box.  Since I couldn't find it, I called a Fort Worth Inspector, and he told me that there is no minimum height for an indoor panel box.  I was planning a 600amp service with 3ea 200amp main breaker panel boxes.  I had a small space to put the 3ea panel boxes, so I wanted to put one below the other two.  The original customer ended up filing bancruptcy and was not able to buy the house, so we just put the standard 320amp service and it became a spec home.  I might run in to this again.
I know that there are different configerations that I could have used. I have found that they would all be more expensive than just installing a meter and 3ea panel boxes. Cost is a factor.
