P pridelion Member Apr 7, 2005 #1 Aside from an obvious culpret like a bad breaker, what could be the cause of a "buzzing" noise coming from a breaker (main load) panel????
wirenut1980 Senior Member Location Plainfield, IN Apr 7, 2005 #2 Re: Panel buzzing Could be the load of the circuit approaching the rating of the breaker.
charlie b Moderator Staff member Location Lockport, IL Occupation Retired Electrical Engineer Apr 7, 2005 #3 Re: Panel buzzing Could be a good breaker that is badly mounted (i.e., loose bolts). Could be someone inside trying to get someone to open the door to let them out.
ryan_618 Senior Member Location Salt Lake City, Utah Apr 7, 2005 #4 Re: Panel buzzing Originally posted by charlie b: Could be someone inside trying to get someone to open the door to let them out. Click to expand... You can't put a doorbell transformer or switch in the panel. Tell the people in the panel to knock loudly, not ring the bell.
N newt Senior Member Apr 24, 2005 #5 Re: Panel buzzing Does this feed nonlinear load which could change freq. which may be the noise you are hearing
