tonype
- New Jersey
Can a panel cover be significantly larger that the panel cabinet (I hope I am using the correct terminology)? Came across a panel (square shape) where the cover is about 6" larger in each direction (3 inch overlap) and secured to the gypsum wall board with anchors (not to the panel cabinet).
Also, the breakers are "Bryant"; panel cover is "Murray" - panel cabinet had no visible ID
