I am looking for any rule that specifies clearance around a power panel enclosure. The enclosure contains 480V service up to 200A, 480V panel with main, 480V 3ph var freq drive, overload relays, contactors, 120/240/480 10 kVA Tx, 120V panel, etc... The enclosure is approx W4' X H6' X D1' with dual hinged doors.
When our equipment is in a certain state, a handrail blocks the enclosure doors from opening. The main disconnect is located elsewhere.
Is this a code violation? If yes what section. If no, are there any access or clearance rules in the code?
Thanks
Thanks
