mdshunk
- Right here.
I rather prefer to mount panels behind a door. That assures that tons of crap won't get stacked there.
romeo said:110.26(B)(3) Clear Working Space The working space requiered by this section must be clear at all times. I took this from Mike Holts book Understanding The NEC. it goes on to prohibit using this space for storage.
jsharvey said:And what homeowner ever reads 110.26???? I've been in basements that you needed hiking equipment and a box lunch, just to get to the panel,,,lol, you can tell them, but that doesn't mean they'll do it,, kind of like the horse and water thing
J.S.Harvey[/QUOT
I agree if you think home owners are bad try visiting some schools sometime,but that is not the issue. The issue is should the electrician install a panel behind a door. IMO no does 110.26(B)(3) prohibit it? IMO yes
J.S.Harvey[/QUOT
JohnJ0906 said:Its called common sense Jim. If I'm working on a panel, I dont want someone opening a door into me.
I still belive it is a good idea to have the OPTION-yes option- to lock the door IF I SO CHOOSE.
raider1 said:Then put a door stopper under the door when you are working on the panel.
Unless there is a local requirement, the AHJ can't require the door to be lockable, as this is not an NEC requirement.
Chris
macmikeman said:An inspector can make a wrong call like the "water source" issue or the door swing and his superiors will many times back him up even though there is no written code that is getting violated. The "water source" issue has happened to me also. It is like the old western movies where they pin a deputy badge on the guy and suddenly whatever he says is law. In my area we have some really good apples for inspectors, and some who would not recognise a code book if you served them lunch on it. The ones who cannot be bothered with learning the code at all still get complete backing from the top , cause after all they are the ones wearing the badge, so they must know what they are doing.
