jeff48356
- Livonia, Michigan
When determining whether a person's electrical panel should be replaced, what standards or criteria do you use?
For me, I would recommend an upgrade if any of the following:
1) FPE or Zinsco brand
2) Any split-bus panel
3) Any panel rated less than 100 amps
4) Any panel where there are sub-panels attached to it. (Indicates possible overload)
5) Any older panel for which replacement breakers are not readily available at big-box stores.
