As Steve wrote, "reasonable" depends on what you are calculating it for.sbyrne said:...Is this a reasonable APPROXIMATION to use?
I come up with:
Phase A @ 66.4A
Phase B @ 49.6A
Phase C @ 54.3A
I used TurboCAD for the ones posted earlier in this thread. They can be drawn in practically most any vector graphics or CAD application. For instance, the following image depicts a quick and incomplete example using Canvas, a graphics application. However, the better applications for such would feature numerical entry of lengths and angles, and also provide snapping and measurment or dimension functions. CAD applications offer better precision.Zifkwong said:Smart -
What program are you using to create those vector diagrams?
Smart $ said:I come up with:
Phase A @ 66.4A
Phase B @ 49.6A
Phase C @ 54.3A
sbyrne said:So who is correct? Smart $ or Steve?
Smart,
how did you come up with the phasor angle on the single phase loads?
Smart,
winnie said:P.S. Smart$'s phasor angles for the single phase loads simply presume that the load is unity power factor, but connected _line to line_ rather than _line to neutral_.
wasasparky said:"So if I wanted to show the LINE currents of a 15 amp single phase load (across A-B) in phasor notation I would draw a phasor with magnitude 15 at angle 0 and a second phasor with magnitude 15 at angle -120. Am I wrong?"
Yes
There is only one current, one phase angle.
sbyrne said:You confused me, this is a 1 phase delta, there is no neutral.
The way I understand things, on a 3 phase delta connection, the line currents will be at 0 (A), -120 (B), and -240 (C) degrees (assuming unity PF). The phase currents will be at 30 (A), -90 (B), and -210 (C) degrees. again, assume unity.
Got any other hints?
sbyrne said:So why are there 2 on the phasor diagram posted above? one at 15amps, -330deg, the other at 15amps, -150deg?
rattus said:Not quite! The line currents will be the vector sums of the balanced loads and the unbalanced loads, therefore the separation will not be 120 degrees.
The 36A balanced currents constitute a large portion of the line currents, but the unbalanced currents affect the phase angles as well as the magnitudes.
The dashed lines in the phasor diagram represent the line currents.
rattus said:It is the same current, but its direction has been redefined (reversed), therefore the phase angle has been shifted by 180 deg. Same argument for the 20A single phase current.
Each of these currents flows in two of the three line, therefore they must be added into two line currents.
sbyrne said:I understand what you are saying (i think). Where I'm having trouble is, How do I determine the angle on the single phase loads? I understand that my phasors will be 15 amp at "X" degrees and 15 amp at "X + 180" degrees. How do I find "X"?
Thanks for all your help everyone!
Actually worse than that... I put the 20A load on A-C, rather than B-C, so it was essentially flipped and rotated... but thanks all the same for catching my mistake, kingpb. (HEY, IWIRE BOB... PLEASE NOTE THE PRECEDING STATEMENT; apologies for the jaunt to others) Nevertheless, I still come up with the same amps but in different order and angle:kingpb said:Steve has to be correct, because Smart has phase A and B flipped.
According to the OP:
A = 49.3 A
B = 66.1 A
C = 54.0 A
Smart $ said:(HEY, IWIRE BOB... PLEASE NOTE THE PRECEDING STATEMENT;
Perhaps the following will help:sbyrne said:I understand what you are saying (i think). Where I'm having trouble is, How do I determine the angle on the single phase loads? I understand that my phasors will be 15 amp at "X" degrees and 15 amp at "X + 180" degrees. How do I find "X"?
winnie said:P.S. Smart$'s phasor angles for the single phase loads simply presume that the load is unity power factor, but connected _line to line_ rather than _line to neutral_. Draw a balanced 'wye', with lines that start at the origin at 0, 120, and 240 degrees. Now draw the outer triangle, with the tips of the wye forming the vertices of the triangle. What is the angle of the lines that form the edges of the triangle?
rattus said:For resistive loads, all load currents will be in phase with their respective phase voltages. The balanced load currents will split into two components 60 degrees apart. For example,
Ia = 36A@0 = 20.8A@30 + 20.8A@-30
Vac = Vrms@+30
Vab = Vrms@-30
This does not mean that the phase voltages are 60 degrees apart. The sense of one of the phase voltages is reversed for ease of calculation. That is,
Vba = Vrms@-150 = -Vab
One must be extremely careful to correctly define the sense (direction) of the various voltages and currents; otherwise your results will be grossly wrong.
Smart $ said:Actually worse than that... I put the 20A load on A-C, rather than B-C, so it was essentially flipped and rotated... but thanks all the same for catching my mistake, kingpb. (HEY, IWIRE BOB... PLEASE NOTE THE PRECEDING STATEMENT; apologies for the jaunt to others) Nevertheless, I still come up with the same amps but in different order and angle:
Phase A = 49.6 @ -351.3?
Phase B = 66.4 @ -117.8?
Phase C = 54.3 @ -250.6?
