E elenTemp Member Location San Diego Occupation EE Aug 15, 2023 #1 Hi, Can someone please explain to me what the circled things represent? I'm pretty sure the bottom number is poles; however, what is the upper one? Thank you, Master Electrician Elen Temp
augie47 Moderator Staff member Location Tennessee Occupation State Electrical Inspector (Retired) Aug 15, 2023 #2 Breaker amperage and # of poles
E elenTemp Member Location San Diego Occupation EE Aug 15, 2023 #3 Would panel PID be correctly represented in this case? You can assume the voltage is accurate. What I am confused about is the bus amps tab Thank you very much
augie47 Moderator Staff member Location Tennessee Occupation State Electrical Inspector (Retired) Aug 15, 2023 #4 I would be little concerned with the 10,000 fault but not seeing the whole picture and the possibility of series rating there is no way to tell.
J jim dungar Moderator Staff member Location Wisconsin Occupation PE (Retired) - Power Systems Aug 15, 2023 #6 Is this a new project you are starting, or an existing project you are simply documenting?
busman Senior Member Location Northern Virginia Occupation Master Electrician / Electrical Engineer Aug 15, 2023 #7 For one-lines like that, I'm used to seeing breaker sizes listed as two numbers such as: 400AF / 250AT with AF being Amp Frame and AT being Amp Trip.
