I had a question concerning a panelboard at my condominium.  I am attempting to sell my unit and on my inspection notice the inspector said:
"On breaker panel, service to home cannot be shut off in six moves or less as required by code. Please repair."
My condo was built in 1975 in Aurora, Colorado. Was this required in the code in 1975? If not, can I get a source to supply to the inspector? I would believe that this was in code at the time, so it would be fine now.
My panelboard is a GE Load Center, catalog number TLM1612RH mod. 2. I also found D873 and P-150 mentioned above the catalog number. It is located on the exterior of the building. The panelboard is set up with 18 disconnect switches on it, in the following arrangement, with the 2 30's and the 2 50's being connected.
30
30
50
50
15
15
15 20
15 20
15 20
15 20
15 20
15 20
If you need pictures I can suppy those as well. If you need any more information I can attempt to gather that as well. Any help is greatly appreciated.
Thanks,
Sean
30
30
50
50
15
15
15 20
15 20
15 20
15 20
15 20
15 20
Thanks,
Sean
