- New Jersey
- Journeyman Electrician
Is a lighting outlet required in a pantry?
IMO, No. Why would it be. It is not a habitable room...much like a closet
I kind of agree. A pantry that is just a shallow closet or even a cabinet may get sufficient light from the adjacent room. However a lot of houses built the last 10-20 years have huge walk-in pantry, some even have refrigerators/freezers in them. Are these rooms still a "pantry" or do we need to better/more clearly define that space?Dwelling. I agree with Dennis, it's not a habitable room and although it's generally used for storage it's not on the list of required lighting outlets for storage areas.
But it definitely needs a light and having a switch is very convenient.
Needs one by code or it would be nice to have one?
I have a walk-in pantry off of the kitchen about 6X8. This room would be pretty useless at night without a light. I can't believe that the NEC hasn't found a need to make this a requirement. :roll:
If this is a loaded question we can dig into code and solve it.
The area is not habitable but it is occupiable which generally requires egress, lighting & ventilation. I think anyone would use common sense and say I'm not going to require or install a light in a pantry cupboard 2' deep but a 10x10 room labeled "Pantry" on a set of plans should "probably" have one (required may differ).
A way to determine if something is a room is the dimension test of the longest perpendicular horizontal dimensions where neither dimension is <7'. (kitchens & restrooms have exceptions or additional criteria as do areas with sloped ceilings). But I'm not saying that's your answer.
Is this something we need to spend a 1/2 hour of research on?
I guess we need to because it kind of sounds like you make up you mind based on your feelings more than code.
My mind is not made up. I just put some information out there.
So how big is the "pantry"?
I was just messing with ya.
Do you run into a lot of large pantries that ECs are not providing lights for?
My point is we may be struggling to fix a problem that does not exist.
