macmikeman said:Sledge hammer's locate buried boxes fairly quickly also.![]()
BAM!!!!
"Not there."
BAM!!!
"Not there, either."
BAM!!!
"Nope, not there!"
THUMP!!!!
"Oh, there it is!"
360Youth said:I try and uncover neatly, but no guilty conscience if I don't. Even if you do find the box with the right size hole, they still have to repair the screw/nail holes when the rock can now be drawn to wall where it belongs.
stickboy1375 said:If you only cut the inside of the box, the sheetrock will not flex and cause the screws to pop, but then you would also need a depth ring to meet code...
I have used this method many times and it is the most effective when the carpenters are being jerks. Tweaking doorbucks with a crowbar in front of them works even better to get a cut or crushed wire in or out they are sometimes not carefull with sawzalls. They just love fixing doorbucks however you need sufficient mass to back it up. This gets your point across quickly.480sparky said:BAM!!!!
"Not there."
BAM!!!
BAM!!!
"Nope, not there!"
THUMP!!!!
"Oh, there it is!"
"Not there."
BAM!!!
BAM!!!
"Nope, not there!"
THUMP!!!!
"Oh, there it is!"
360Youth said:Doesn't it leave a bulge in the rock if you don't cut out around the box??
LarryFine said:What I don't understand is not charging for having to locate buried/covered boxes.
LarryFine said:What I don't understand is not charging for having to locate buried/covered boxes. .
