The Code (NEC 310.4) requires conductors run in parallel to "be of the same length". Is there a requirement to how much of a difference the conductor length can be between the longest to shortest. Example. If I had 10 conduits filled with 600 mcm copper between a pad mounted transformer and a switchgear there is bound to be a "short" leg and a "long" leg. Does the code speak to this?
