Dark Sparky
- USA
- Electrical Engineer
I'm reviewing a concept proposed by an electrical contractor. There is an existing 480V, 3 phase, 400A distribution panel DP1, fed from switchboard MDP via a 400A breaker in MDP. Proposal is to intercept (more below) that feeder via a new J-box just below DP1. Then run 2 sets of 4-#3/0+G in 2-1/2" conduit immediately to a 400A enclosed circuit breaker (located near the intercept). Continue from that breaker about 175' to a new 400A distribution panel DP2.
1. Because the ampacity of the feeder (2x200A=400A) isn't exceeded by the rating of the upstream 400A overcurrent device, I understand that the feeder conductors are NOT considered to be tap conductors, per the definition of tap conductor in 240.2. (The intercept below DP1 is not considered a tap.)
2. Because the feeder intercept (point of supply) isn't considered a tap, I understand that there is no rule regarding additional overcurrent protection, and the new 400A enclosed circuit breaker could be anywhere convenient (in other words, it does not need to be a given distance from the feeder intercept).
3. I have no issue with the volt drop, even at a full 400A load.
4. The proposed ground wire size for the parallel feed was unclear. Per 250.122(G), etc., I would supply a #3 ground in each conduit (full-sized ground in each conduit, sized for 400A upstream breaker.)
Please let me know if anything above needs more clarification, is incorrect, or questionable. Thanks in advance as always!
