What I Found...
What I Found...
There is a 42 cir. CH 200 amp in place now. There are at least two openings left. A sub-panel 8 cir fed with a 100 amp from the main service. There are three slots open in the sub.
The customer is going to change a cook top out from a 30 amp to a 40 amp required unit, no problem just pull new line for cook-top.
Replace double oven with a new double oven with Advantium(?). Told this required a separate circuit for the 120v portion. again no problem adding a circuit for the 120v.
I did find that the sub-panel was fed by a 2 conductor with bare ground (SE). All of the grounded and EGC are mixed all over the place in the sub.
