When sizing the EGC for a parallel circuit, what do you start with (base conductor size) when determining the upsize required on the ground. For a large feeder, there is a number of different parallel combinations. What is the true base conductor size?
Using a feeder for a 1000A 3-phase main breaker in a switchboard, you can use 3 sets 500mcm at 344A each (derated for 80% as nonlinear) for 1032A total. Or 4 sets of 300 at 256A per set (derated for 80% as nonlinear) for 1024A total. Even though the 3 sets of 500 may make more sense, is it considered an increase in conductor size meaning maybe a larger ground?
What is the base conductor size; starting point per say?
