Parallel or not
FionaZuppa
AZ
Part Time Electrician (semi retired, old) - EE retired.
Make sure the bridges are the same
same as 3 ph with 1 ph removed
can i ask how this is paralleling two bridges?
FionaZuppa
AZ
outputs in parallel
each carries ~1/2 the load
hmmm, not true, the current vector is not shared (paralleled) across the bridge pair at output. what you have done is made each bridge (4 physical diodes) into 2 logical diodes. perfectly legit this way because of variances in making of diodes. :thumbsup:
Ingenieur
Earth
what???
the ouputs are not in parallel?
and each doesn't conduct 1/2 cycle thereby delivering 1/2 the power?
lol
gar
Ann Arbor, Michigan
EE
161219-1957 EST
If one simply looks at either bridge, then it is seen that by the external wiring that two diodes within the bridge are paralleled.
FionaZuppa
AZ
Don't get sucked into the abyss, someone is having fun.
there is no abyss, gar is correct.
also, the comment about half power per bridge is ok since the current vector leaves one bridge and returns on the other, they just aint parallel, thats all.
the comment about each only conducting a half cycle is also false. each bridge conducts for every 180 of the AC :thumbsup:, the amps leaves one and returns on the other for every 180 :thumbsup:
where do you find 1kV diodes for this job at hand? amps wont be the issue, finding 1kV rated might be??
Ingenieur
Earth
if gar is correct you are incorrect?
The outputs are in parallel
180 deg (Pi) is 1/2 cycle, it's the same thing lol
1 cycle is 360 deg (2Pi)
GoldDigger
Placerville, CA, USA
Retired PV System Designer
161219-1957 EST
And the other two diodes of each four diode bridge never conduct at the same time as the first two.
It becomes a full wave rectifier with each "diode" consisting of two diodes in parallel.
In theory, if current splits equally, able to supply twice the current a single bridge wired as a full wave bridge.
FionaZuppa
AZ
Another thing to consider is PIV. At 480Vdc you'd need devices rated at 1600V.
why 1600V
isnt 1.5x peak a good buffer? a fast pulse on a coil is gonna give back a nasty flyback, so that needs to be handled properly either with some decent zeners to GND or hefty reverse diode across the load (coil). i like zener method because of the freewheel diode will allow.
your Pi is spot on, your understanding of how the amps are flowing is not. for any given 1/2 cycle, amps flow in one direction only, it leaves one bridge and returns on the other, thus i may infer that both bridges are conducting at the same time, all the time, regardless of what 1/2 cycle you look at (less the dropout region of diode, etc).
Ingenieur
Earth
why 1600V
not my Pi
everyone's
surmise to your little hearts content
the diodes/bridges are operating in parallel
FionaZuppa
AZ
not my Pi
everyone's
the bridges are not in parallel, they operate in series, sorry.
what you have is, each bridge has 2x two diodes paralleled to handle 2x the amps per diode pair, each half of the logical bridge is on two physical bridges. just take a pen and follow + to - (AC) from one side to other, when you get to other side flip the voltage over and then follow back + to - (AC)
gar
Ann Arbor, Michigan
EE
161219-2124 EST
Redraw the circuit of post #9 and you will see that you have a single bridge circuit with each segment of the redrawn circuit consisting of two diodes in parallel.
Thus, the the circuit has paralleled diodes. The paralleling of the diodes occurs within a diode bridge package. One bridge package provides only two segrments of the real bridge circuit.
Ingenieur
Earth
:D
Both bridges supply power/current to the same conductor
sounds like parallel to me
FionaZuppa
AZ
161219-2124 EST
correction
One bridge package provides only one of two segments of the real bridge circuit. as is, it takes two physical packages to complete the ckt.
FionaZuppa
AZ
:D
really? please show us a trace when bottom AC is + and top AC is -, lets see how both physical packages provide amps to the +DC terminal at the same time.
hint: one bridge is a current source, the other is a current sink.
Ingenieur
Earth
Show me how 180 deg (angular not temperatre) is not equal to Pi or 1/2 of a sinusoidal signal
as you stated before: not 1/2 cycle but 180'deg lol
GoldDigger
161219-2124 EST
And the paralleled diodes within each bridge assembly are much more likely to be matched in characteristics and temperature compared to diodes in separate bridge assemblies.
I see this as a very elegant way of effectively doubling the bridge capacity with less concern for diode characteristic mismatch!
Thank You gar.
FionaZuppa
AZ
Thank You gar.
this is the exact reason why two physical bridges are used in series, one phys bridge on each side of the load.
FionaZuppa
AZ
180 is indeed half cycle. you dont understand how that schematic works, so here, just follow the arrows per half cycle. at no time, EVER, are both bridges being current sources to the DC+ bus !!! have i made this clear ?
