Designer69
hey guys why is it a bad idea again to create multi paths to ground?... ie separately grounding each panel instead of running the neutral to one central point?
thnx
thnx
It may not be a bad idea. Unlike grounded conductor paralleling, there should be no 'normal' current on GEC's.Designer69 said:hey guys why is it a bad idea again to create multi paths to ground?... ie separately grounding each panel instead of running the neutral to one central point?
Okay, more specifics, please.Designer69 said:actually Larry I was talking about the neutral (grounded) conductor
But only on the load side of the service disconnect. It is the normal installation on the line side.brian john said:Parallel neutrals 1/0 and above OK, multiple paths a BIG NO NO.
