Suppose the GEC required is a 2/0 AWG. If you run 3 sets of #4AWG and irreversible bond both ends of the cables, would that be a code violation?
If you have 3 raceways, a full size GEC is required in each raceway.
Why would a GEC be required in any of the raceways?
PVC, spec.
Some AHJs do not allow conduit to be used as a GEC.
If they haven't made a formal amendment and they are inspecting for NEC compliance they have no choice in the matter.Some AHJs do not allow conduit to be used as a EGC's
Roger
https://www.phoenix.gov/pddsite/Documents/2012_amend_index.pdf
Page 270
I had them enforce with RGC too...
The answer is yes it's a violation. You need to size the GEC according to 250.66 which has no provisions for paralleling.
The relevant question is whether the paralleling prohibitions exclude GEC's.I thought I read once in the forum that the NEC is a permissive Code meaning that if it doesn't forbid it then it is allowed, or was it the opposite that I read?
IMO, it would be a violation however, the code does not address this for grounding electrode conductor's. I would use 310.10(H) as a premise that doesn't allow parallel for smaller than 1/0. Again the code does not mention grounding electrode conductor's.
One can say that since the code doesn't mention it in 310.10(H) then it is not permitted to be paralleled.
