I have a 400 amp outdoor disconnect that connects to a 6' interior gutter with 3" rigid conduit. The distance between the gutter and the outdoor disconnect is 40'. If I parallel 3/0 wires can they be installed in the same 3" conduit? Plus, am I required to bond the ground and neutral conductors at the first means of disconnect which would be my outdoor disconnect or is this bond made in the 6' gutter. I know I have seen it done either way on past jobs, but what exactlly does the NEC require? Thank you for the help.
