We have a project where our electrician installed low-voltage wire on the rough-in for two miniature LED lights. He installed one LV wire from the future driver location to the first light and then from the first to the second light. Fast forward to the finish. The driver is capable of powering up to three lights, having terminal blocks for three individual wires from three lights. After taking apart the driver, we discovered there are actually three individual drivers inside - one for each light. Which would be fine if we would have ran a separate wire to each light. So my question is, is it possible to wire two of these individual drivers together in parallel to power up two lights from one wire? The same 120v switchleg would connect to the inputs on both drivers and both (-) would tie together along with both (+) being tied together on the output side. Called WAC Lighting(it's their product), and they said it would not work, but didn't give an explanation why. It seems, in theory, it should work - output voltage would remain the same but output capacity would double. Hoping somebody smarter than me can weigh in. Thanks!
