mopowr steve
- NW Ohio
- Electrical contractor
I've been looking at a nightmare.
But have a question based on the fact as Mike Holt has informed us that current only returns back to its source......hold onto this thought.
Here's the situation..... There is a 480 delta to 208 Y transformer connected backwards ( 120/208 volt service to building) which is being used to step-up voltage out to a parking lot lighting.
Now since there is no place on the 480 volt side of transformer to connect ground ( I guess one could say ~ isolated supply?~ ) would a person receive a shock at all if a wire should fault to pole? Cause where would the current go ? Nowhere, because there is no return path back to transformer?
So should Mike show an example of such a set-up?
