Partial Outage, Breakers OK, Lights Dimmed, Not quite sure what to do
chrisgfrank
New User
Canada
So, funky problem.
My son goes to turn on the tv downstairs this morning. For 5 years it has been plugged into a surge protector, along with his xbox, a surround sound unit, receiver, dvd player, and a powered subwoof. None of the surround sound components have been turned on in ages, as our upstairs tv has become our main movie center. He occasionally unplugs the xbox to take it to moms, but otherwise nothing has changed.
He said that as soon as he turned the tv on (its an older 32" tube style tv) the lights dimmed slightly, then resumed power, then everything went out. The entire downstairs living room has no power (plugs or light fixtures), the light fixture in an adjacent bedroom doesn't work but the plugs DO, and the lights AND plugs in the other adjacent room work. Also, the bathroom off the living has full power. Everything upstairs is normal.
Naturally I assumed it was a breaker. Not so much. I even reset ALL of them including the master. I tested and reset all the GFI plugs (even though these rooms still had power). I went as far as to turn open up the breaker panel, turn off the main power and all breakers, remove the one suspected bad breaker, pull a matching breaker from the opposite side (my understanding is with 220, 110 is split down each side?) and tested it. No luck. But even if one of the 110 circuits was toast, why would all other breakers on that side work. I subbed in a good breaker of the same amperage from a known working circuit into the couple that I thought it could be (two are labelled "downstairs lites and plugs", which is helpful....) and still had no power on that circuit. Just for kicks, I took the wire from the bad circuit and plugged it into a known good breaker on the other side and flipped the power on - no luck. So I reconnected everything as it was originally and in my head I can rule out bad breakers.
Next I went with a popped off backstabber on one of the switches or light fixtures. I pulled a few random ones in that room (two switches, one plug, one fixture) and they're all screw type - not spring type backstabbers. All the wires appeared secure, intact, unburned, and the grounds were all secure. For kicks I gave each one a little wiggle and made sure they were tight with the screwdriver. I did NOT do this with all of the plugs/switches/wires. My assumption is that if SOME are screw style and not backstabber style, I probably don't have a popped off backstabber.
Which leads to me this: Now what?
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC? Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
