Hello,
Does NEC prohibit passing wire through pre-insulated connectors like POLARIS's double-entry Pre-Insulated connector?
I'm wondering if I can tap a conductor and not have to use a 3-port connector. I would just use a 2-port connector, remove insulation from middle of wire, pass it through one port then in the other port I would have my tapping wire. Obviously there would be no break in the pass-through wire.
Has anyone done it and passed inspection ? Any reason it's a bad idea ? I couldn't find any code that addresses this.
Manufacturer doesn't either explicitly prohibit or allow this.
Thanks!
Thanks!
