jason619
- Corpus Christi, TX, USA
Kindly go through this attachment. The neutral is grounded as shown.my question is
1..when the current returns through neutral wire, why dosent it directly go to the ground as there is a path available at point N.
whts the reason for this.
2..when we say current has to complete its path.what does this mean.
i mean if we have a load on the secondary side of transformer and the transformer is at a good distance from that load.when the circuit is complete, the current flows through hot wire and returns through the neutral wire.is this the meaning of CURRENT HAS TO COMPLETE ITS PATH.? if this is true, then i believe that current will flow back and forth between load and transformer secondary via the hot and neutral wire regardless of the distance.
for example the step down transformer feeding a colony.all the colony loads will be fed from transformer secondary and the current will flow from all the transformer to the load and come back....is it so????
