gray.one
- Reston, VA
I disagree with the sample problem solution in the book.
The losses will be directly proportional to length of the line. The terms inside the log in the definition of db should be multiplied by 10. The db should not be multiplied by 10.
When you have two lengths of cable in series you multiply the two loss ratios. Since dB is alog og loss ratio you add the logs to get the log of the product.
